Old 09-27-2010, 06:58 PM   #5 (permalink)
autoteach
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
You cannot use fuel injector duty cycle by itself for figuring out fuel consumption. As someone said above, the opening and closing affects the actual open time. The other part that you are overlooking is the fuel pressure. There are very few cars on the road that use steady state fuel pressure, so figuring out flow will be tough. As for using engine load, that is different, although, still unable to tell you consumption without a BSFC map.
