Originally Posted by Ptero
Mount: Cut out the soft plastic ring, then slide the base underneath the edges of the speedo housing and the a/c housing. Then lock the lever.
Got it this time, thanks! I'll post a pic of the base for the next guy that tries it.
Did you do the VE Enable thing? I believe the right VE RPM setting is 4500 to help out with the MPG readings on the smart Fortwo; you'd mentioned not getting very good numbers for that. Since we have a MAP sensor, not an MAF, that needs to be enabled. I'm not getting wild numbers like you reported, and I haven't had time to do a calibration yet (just got it in the mail at work today).
