09-28-2010, 01:54 AM
#119 (permalink)
Pokémoderator
62.4 mpg
Hello -
Beat my old work-to-home record by 5 MPG :
Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
ROUTE : 105 East -> 710 North -> 10 East -> Exit Freeway at Walnut Grove => Roughly 27+ miles
NET ELEVATION CHANGE : ~210 feet uphill
SCANGAUGE "CURRENT" READINGS :
62.4 MPG,
0.4 Gallons,
206 Water Temp Max,
26.3 Miles,
1969 RPM Max,
0.5 Hours,
57 MPH Max,
44 MPH AVG
IAT READING : Hot Air Intake + grill block led to Input Air Temp readings of around 130+ degrees F.
WEATHER(.com) :
88 degrees F,
Clear/Fair
22% Humidity,
48 degrees F Dew Point,
29.74 in. Pressure,
TIME : ~8:20 PM to ~8:50 PM, ~30 minutes
RECENT CAR CHANGES : New pizza pan covers. Car running well at 200K miles.
HYPOTHESIS : The weather. Hot as Hades. The numbers compare favorably to my previous record of 57+ MPG. What's the difference? Maybe the wheel covers. The tires need replacing, so they are very LRR right now. There was a slow truck that I milked for great MPG on the 105 East. The car was heavier because it was carrying a load, so maybe it coasted farther. Maybe I'm 15 months better at this. Beyond that, I really don't know.
CarloSW2
