Did you do the VE Enable thing? I believe the right VE RPM setting is 4500 to help out with the MPG readings on the smart Fortwo; you'd mentioned not getting very good numbers for that. Since we have a MAP sensor, not an MAF, that needs to be enabled.
Thanks for the tip. I'll try that. Maybe that was the problem. I've been getting an idle RPM of 940 which doesn't seem right.
