euromodder, I find the Scangauge corrects better if you make your adjustments small. If you are correcting for fuel used at the fillup, make your correction only half of actual, and the gauge will close in on accuracy. Eventually your changes will be less than 2 liters and you should stop correcting at that point.
I'm not coasting, I'm shifting slowly.
