Weather you are using two actuators correct? Also do you have the wires ran like on the first page?
If so then it looks like you have A wire running from the switch to a point where you split the wire to both actuators. Run a separate wire for one of the actuators to a switch to break its circuit.
Here is pic to show what I'm saying I would explain better but have to leave for class now.
