get a screw
The hazard button on your S10 is held on by a small screw.
Probly just the screw came loose and you can replace it.
If you lost the whole button assembly,
Button, spring, base, screw
They sell it at your local dealer for cheap.
or you can just put a small screw in the plastic pull tab and use it that way.
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
