Old 09-29-2010, 11:18 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I'm confused about where 160 baud is used and whom is talking to whom in the aldl exchange. But the attached circuit should be a good starting point, set one pin for the rising trigger and the other for the falling, and manually use a jumper for start the aldl spewing data.
There is also a pulsein function, but I don't know if arduino supports it, or if you can reset it in time. I think it blocks program execution by default as well. arduino programmers are generally not accustomed to the quasi-threaded environment of interrupts.
Last edited by dcb; 01-30-2011 at 02:10 PM.. Reason: changed resistor val to 10k for stronger signal
The Following User Says Thank You to dcb For This Useful Post:
FalconFour (09-30-2010)
