Old 09-30-2010, 10:14 PM   #11 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Gasoline does slowly degrade but the trouble isn't with the gas itself, its what the gas does to components it touches while it sits.
The best example is when the gas isn't in a perfectly sealed container, portions of the gas slowly evaporate and others slowly degrade as the substances holding them in solution go away. The end result is a tough varnish.
Your carb usually isn't air tight and gets varnished rapidly when you leave a motor sit with old gas. As the gas ages it leaves more varnish after it evaporates, clogging your carb.
Even when gas is in a well sealed container it tends to varnish the surfaces it touches when it sits, just more slowly.
So the issue isn't with your old gas, it would be with you not running your engine for a period of a month or more often.
Cheers
Ryan
