Old 09-30-2010, 11:27 PM   #11 (permalink)
EdKiefer
Originally Posted by Meph View Post
sorry i think i edited my post as you posted this one, reducing the overlap is the theory behind increasing torque by making better use of the combustion pressures at lower rpm's resulting in greater efficiency/mpg?
meaning Id need to advance exhaust and retard intake?
yes, that will lower overlap , lower lobe separation angles. altering both cams 4deg kept overlap the same but advanced timing in relationship to TDC which also has affect of advance = better low end and retard = better top end . with DOHC being able to do both I would start with intake then move to exhaust as generally intake is more important .(thats why most VCT is done on intake side ) .
