Old 09-30-2010, 11:29 PM   #12 (permalink)
Meph
Meph's Avatar
240Z - '73 Datsun 240Z 240Z
90 day: 34.41 mpg (US)
cam gears are in crank degrees, so im good.
the cams are advertised as "Set the exhaust cam gear to +1.5 marks on the cam gear (+3 actual degrees) and the intake to -0.5 mark (-1 degrees). On average this setup yields 5-7rwhp." ...... oh god, this would remove overlap as per the example and make no sense with everything else we discussed! nothing make sense! It should reduce power not create more! oh god! *resets everyting to 0 and hides under the bed*
