Originally Posted by Meph
cam gears are in crank degrees, so im good.
the cams are advertised as "Set the exhaust cam gear to +1.5 marks on the cam gear (+3 actual degrees) and the intake to -0.5 mark (-1 degrees). On average this setup yields 5-7rwhp." ...... oh god, this would remove overlap as per the example and make no sense with everything else we discussed! nothing make sense! It should reduce power not create more! oh god! *resets everyting to 0 and hides under the bed*
It really depends on cam specs and were you want peak power .
Are these cam's stock or aftermarket ?
read second link I posted above first , then the first one. That should help you understand relationship of timing events some .
Note : that pic of cam rotates CC , which I bet yours turns clockwise , that confusing if yours rotates different direction .
