Old 10-01-2010, 05:18 AM   #9 (permalink)
Jehnavi
Heat pump water heaters use electricity to move heat from one place to another instead of direct heat. Therefore, may be two or three times more energy than conventional electric resistance water heaters. You can move the heat, heat pumps work like a refrigerator reverse.Install the state of excess heat as the boiler room. Heat pump boilers are not working effectively in a cold room. It is usually cold in space can also install heat pumps that combines heating, cooling and water heating. Together, these systems draw heat inside during the winter, outdoor air and indoor air in summer. Why remove the heat from the air, each air heat pump works more efficiently in hot climates.
