Old 10-03-2010, 11:34 PM   #20 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
I don't think drilling an exta hole is a good plan, however if you already have an opening for cooling air that goes through the radiator you could use any energy left in the radiator exit flow to drive a mini air tubine then duct the exit air from the mini turbine to a low pressure area it might work. The experament is well worth a try. If nothing else you will find out what doesn't work. The process will teach you a whole lot of other stuff that may become useful in some other experament.
