Old 10-05-2010, 05:32 AM   #4 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by NachtRitter View Post
Seems like you could take advantage of DFCO, where you get the benefit of both the vacuum being generated for the brakes and zero fuel use of EOC... At least what I'm understanding is that the route is steep enough to require brake use, so taking advantage of engine braking too would (slightly) reduce the need for brake use.
i'd agree with this.
Currently i have a 2 mile section on my commute where i can p&g between 60-50mph by doing the following.
Use slope to accel car up to 60 in IDLE
Use dfco in 4th to engine brake to 50
Th slope is such that the car will often maintain above 50 for quite some time in dfco.
I also use dfco for slowing whilst driving in 'accordian' traffic
helps me keep my distance and keeps brakes avail if required in addition.
