Old 10-05-2010, 01:36 PM   #28 (permalink)
talldudenumber5
klr 650 - '08 kawasaki klr 650
The van - '15 Dodge Grand caravan Avp
i found this model ( Small Alternator, Mini Generator (YAF-54) ) that may get me the amps i need especially if i do 2 of them plus i could do 2 solar panels like this to trickle charge what the wind does not and they would fit into my sun roof and still allow me to use it. ( 1.5 Watt 12V 90mA MINI SOLAR PANEL for CHARGING BATTERY - eBay (item 130436312637 end time Oct-03-10 20:45:07 PDT) )
i have decided to do a fan behind the radiator since being after the radiator i have nothing to lose in drag or cfm in air moving in to cool the radiator / engine. plus when the fans kick on turbo boost to compensate for them coming on
this idea is very feasible and could replace an alternator it would not be good for a vehicle with heavy electrical load ( bass systems, lots plugged into the cig lighter, lots of lights, etc.)or for alot of turning the engine on then off but for a hypermiling vehicle that neutral coasts instead of EOC this could replace the alternator with out worry of dead battery.
also side note: the solar would trickle charge the battery to keep it topped off which would help the battery last longer and reduce the amount you have to replace those expensive batteries
SCANGUAGE IT REALLY WORKS
