Results
Hey guys,
Ive been testing different combinations of settings and Ive come to a conclusion for my car.
I found that +4 exhaust and 0 intake resulted in more torque down low
+6 exhaust and +3 Intake resulted in more torque than just +4
What Ive chosen to run : 0 , 0 (stock)
What I experienced
the increase in torque was a noticeable one, the issue is that I would only feel this torque increase with load on the engine, -18" to +12 psi. below this load, at -18" to -22" the engine seemed to produce significantly less. Where i was once cruse at 1.5 injection time in town, jumped to 1.6-1.7 be because i need to give it more throttle.
I think for many eco cars out there, this mod would very well help, because when your driving your engine is loaded to say -10" to -16" normally, my Datsun will cruse at -20" on flat ground, due to the light weigh body and engine swap. I only noticed a bonus to MPG's at much higher speeds than i usually drive, where the engine is turning a higher RPM and was under more load. I changed my cams back to stock part way though a drive and noticed a significant reduction in fuel injector times when cruising at very light loads (as i most often do)
So to conclude, I did produce more torque, but not in my required engine load area. Someone with a small engine would probably have benefited from his change where it only hindered me
Thanks for the input everyone. I may get ambitions and do some more testing but for now I think Ill take a quick break from it
