Old 10-05-2010, 02:38 PM   #4 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
KCF3712 -
I think that both at once are preferable, but hypermiler01 is correct, the upstream (pre-cat) O2 sensor is more integral to closed-loop operation. Also, for your Kia Spectra, the OEM brand is usually preferable. For instance, in my drivetrain, the OEM was Denso. When I switched to a Bosch sensor, it would raise error codes more frequently. I was told at saturnfans.com that the Bosch sensor is more "sluggish" in it's response rate, so the ECU/PCM thinks there is something wrong, so it raises a false error code.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
KCF3712 (10-06-2010)
