If you aren't suffering from bad gas mileage, you are probably better off waiting until one fails then to just replace it for no reason. The cars computer does a decent job of knowing if they are bad. Plus O2 sensors are pretty expensive. I know because my gas mileage dropped off significantly about a month before my check engine light came on for the bad O2 sensor.
