Those are both good modules for the vintage. That toshiba is widely used in forklift chargers being run at 20+ khz in a switching converter topology. I would still run at 8khz though as it makes life easier on the parts and reduces switching losses by 50% compared to 16khz.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
