You may try heating the shaft to loosen the pulley. Putting the temp around 300-500 degrees should loosen it up enough to get it to come off.
Careful about using the prybars. IT does work but it's easy to break a chip out of the pulley in the process.
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
