Originally Posted by Meph
In my load load-lower rpm range I'm running around 36-43*, I think i can still push it but I want to build a knock sensing circuit first. With my new slightly more aggressive ignition map and lowering my a/f to 15.87:1 I just returned 35.5MPG, new record
43 deg sounds pretty good but that depends on what your able to run , say max TQ mid range at 0 vac " and max boost .
Is it like,around 36@0 vac and 28-30@ boost (this will depend on how much but rough valve).
Generally could might be able to stand 8-10deg of part throttle advance , so in above it be like 45 deg max .
You could maybe make a electronic stethoscope , I have seen a few DIY on it from old electronic parts .
