Old 10-06-2010, 05:14 PM   #161 (permalink)
brucey
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Drilled holes this morning, spent a good hour tapping them because aluminum galls up so easy. Kerosene helped some at least.
Went to use a pulley puller and it doesent work. Even with the impact gun (dumb, I know.)
I am now sanding the leading edge of the motor shaft in hopes that rounding it off will help get the pulley on and off.
Currently though, I set my oven to 'atomic' and set the whole assembly on top of the oven to radiate it, hoping the heat will help it move off.
