Aerohead is probably right. Anair dam plus a belly pan would give the best MPG.
I modified my air dam this summer. It was 3 inches above grade and it grounded at the least provocation (like braking or the steps in my driveway). It worked really well. It was worth at least 0.75 MPG.
But I got tired of listening to it grind, so I shortened it up to 9 inches above grade.
Now it doesn't drag or look dorky, but it is nearly worthless in improving MPG.
I'm trying to learn GIMP so I can shrink down my pix to a size the site can handle.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
