Old 10-07-2010, 07:46 PM   #38 (permalink)
aerohead
stability
If you are to streamline a car the location of the center of gravity is especially important in relation to the center of 9aerodynamic) pressure.
At high speed,and exposed to a side gust,a car should weathervane towards the gust direction,canceling out the yawing moment.
Typically,for streamlining,a front engine with front wheel drive is the most stable.
A rear fin can be a palliative to compensate for an improper CG/CP bias.
