I haven't done any testing of the injectors myself, but I found a little more info about the Honda DPFI here:
90 model civic dx injection operation from factory manual - Car Forums and Automotive Chat
While trying to find a way to monitor the FI on time tobe able
to monitor fule use real time I had a dual channel oscillsocpe
connected to botht eh main adn aux FI.
There is no simple way to discribe the "firing" events.
The main cylcled pretty much the way I expected.
But the aux didn't behave in what I would consider to be
any logical manor. During cold starts the main and aux are
both one about the same times. As the engine warms up the
aux on cycles are reduced except for odd cyles that do not
relate to acceration or engine speed. For instgance,
while driving on a level stretch of highway, keeping speed
and throttle postion constant, the main chugss away more or
less like I expected. But at odd intervals the aux would cyle
on for no apparent reason.
In general any demand for increased engine RPM, ie opening
the throttle, will result in the aux opening for variable
periods. Deceleration using the engine had the aux cycling
more then the main. I finally found this link,
<http://www.ggimages.com/rx7/pwm.html>;, and I use 2 of them
to monitor both main and aux. I had thought about trying to
combine the outputs so I only had to deal with one disply,
but after some practice I can now minmise my fuel consumption.
I was intrigued by the lowest intake manifold vacuum does
not translate to best fuel economy.
I am sure that a real micro computer whiz could read the data
from the ECM EPROMS and build a table that shows on ratio for
engine temp, MAP, O2, RPM and BAR but this is way beyond my
skill set.
My 1991 Civic has been a test bed since last fall.
I have played around with lots of odd stuff trying
to understand the ECM better. You can fool the ECM
into thinking the secondary injector is present and
the car will start, if the enigine is "warm". I didn't
try too long but my car starts within 3 or 4 secs
worst case with both injectors. But with onlh the
primary I cranked a cold enigne for 15 sec. I don't
think the primary alone can get the mix rich enough
to start when cold.
However drivibility will be really, and I mean *REALLY*
bad. Jerky take offs with odd surges in acceration.
And during downshifting you will experience mild back
firing, more of a back burping.
I have not been able to understand why under steady load,
steady speed on a very level 5 mile stretch of road, the
primary just toggles like I expect, but the aux/secondary
opens at what certainly appear to be random events.
During downshifts it is clear. The primary shuts down and
the aux fires as determined by engine speed and presence of
breaking, ie the brake light also feeds the ECM. This is way
you are better off using the engine to slow down then to
shift into nuetral or hold the clutch in. At idle the primary
is just chugging away, during downshift only the aux is firing
and then only enough to, I think, keep the engine alive.
If you monitor the O2 sensor you will see the mix has become
rather lean.
