Old 10-09-2010, 12:19 AM   #30 (permalink)
amcpacer
Edsel 2.3 Turbo
Today I went to the wrecking yard and found a clutch pedal from an 80s Mitsubishi pickup and a gas pedal. I wanted to find Mustang or Thunderbird parts but nobody had such parts in town and the Mitsubishi parts look like they will fit with some custom cutting and welding.
When I bought the engine it came with a wiring harness but for some reason the only three things that can plug in on the harness are the Vane Air Meter, O2 Sens, and Distributor. None of the other plugs match what is on the engine. The connectors are different size or sometimes female to female ends. At this point I have downloaded wiring diagrams that show the pinouts of the computer and am about to cut into the harness and route the wires to the proper sensors without using the multitude of different connector sizes. This will be very time consuming and it would be so much easier if I just had the proper harness for this engine. Megasquirt would be so cool down the road but the Ford computer programming may be just fine for efficiency if I can have the patience necessary to make the electronics work.
The suspension on the car was extremely soft when I was driving it with the V8. I would think slightly firmer suspension of cut springs may be desirable. It would not be able to be driven right now since the suspension is maxed out full height like a gangster with hydraulics. I was thinking that perhaps an air bag style spring is available and would make for getting the ride height an easy task.
At least the hard part of hanging the engine and trans is out of the way. Now I have to put up with jokes from friends about "Fix or repair daily, Failed on race day, Driver return on foot, etc......
At least I will be the one driving the cool efficient classic car!
