lets see there is a round plug that should cover the injectors ,water gauge sensor in extension fitting on lower IM outlet) . the other sensors like ECT, TPS, ISC and knock went into main harness same with a EGR controller and boost solenoid . there also a rad fan switch sensor in lower intake manifold .
On the suspension could it be it just needs to be rolled a bit as with no motor the tires pull in at ground or maybe the shocks froze up when they got extended .
