Old 10-09-2010, 12:54 PM   #29 (permalink)
aerohead
Fit vs Lancer
Originally Posted by Fit View Post
Just an update... after digging around some more, I located this paper votrex generators:
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
Seems the design of the Vortekz brand generators are pretty efficient as they are simmilar in design to the mitsubishi ones.... then again, of course mitsubishi would say their product is close to optimum
The vgs helped with Mitsubishi's Lancer,as the Lancer has a trunklid for which the separated airflow from the roof can re-attach with the help of the vgs.
The Fit has no 'structure' on which the flow can re-attach to after separating off the roof.
The entire premise of the VG is violated by Honda's architecture.Better to burn your cash on a cold winter night.At least you'll have the benefit of the heat.
