Old 10-09-2010, 04:43 PM   #6 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I was going to install a 95cm (=100MHz quarter-wave) antenna under a plastic or fiberglass body panel, but the stock antenna located inside the car is doing an adequate job. The stock antenna is about 40cm long, and is powered. Correction: it was powered.
