Old 10-10-2010, 09:49 PM   #27 (permalink)
Grant-53
Seat height is determined by leg length and crank height. The aero tuck position takes some getting used to. I've made my own aero bars from a set of bar end grips, 1-1/2 inch aluminum angle, and some 7/8" tubing for vertical grips. The fairing needs to cover the rider from the shoulder to the knee. The lower legs have less drag than a full width fairing and you need to have your feet clear for stopping. The shape can be defined by a combination of ellipsoids having the top half flatter than the lower half to minimize lift.
The rear section may need to move to throw a leg over if the top tube is high. I have used 4mm coroplast for some pieces. I have experimented with 1 inch hex wire mess glued between two pieces of 5 mil plastic ribbed with 7/16 OD nylon tubing. The less flat area on the sides up front, the less trouble you have with cross winds.
The Following User Says Thank You to Grant-53 For This Useful Post:
HeadlessNorseman (10-10-2010)
