Germany used coal gas generators in their Kubel-wagens at the end of the war. When my father finished his 30 missions on 6-6-44, he ferried planes to Paris at Le Bourget. There were acres of parked Kubel-wagens sitting near the airport. All of them had coal gas generators, but they were also all booby trapped.
The problem that I read about is the tar residue from generating gas from coal, and probably even more so from wood.
Maybe a separator and a pressurized tank of fuel would be the solution, just a guess.
I know you can smell the turpentine from a rotten trunk of a dead tree. It is much more flammable than the wood itself.
As far as working with your existing FI system, the easiest way would be to have a pressurized tank of your alternate fuel and feed it into the intake manifold. The system should reduce the amount of your original fuel that is delivered to the engine.
regards
Mech
