Old 10-11-2010, 03:34 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
that wasn't what I said I don't think. Do not power the atmel with ignition power, but you can power the backlight with ignition power and the appropriate circuit bending, so that it turns off with the car. Are you sure it isn't going to sleep but maybe just a mismatch between backlight code and configuration?
can you put it on the cpu screen, note the time on the guino, walk away for 10 minutes then come back and see if the time goes back to when you last touched it?
