Old 10-11-2010, 03:58 PM   #12 (permalink)
wyatt
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
I re-read what I wrote, and it does sound like I am powering the MPGuino off of switched power... what I meant is: I have tapped switched-power in the past, so it is readily available.
I will try the cpu screen this evening if I remember, I may also try the disconnect INJ and VSS to see if that does anything (each individually, CPU, INJ, VSS).
