Old 10-12-2010, 08:07 AM   #107 (permalink)
usergone
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
Originally Posted by dcb View Post
I updated the wiki with the following diagram, any thoughts?
regular diode is probably fine, dunno.
DRAFT
Maybe switch the input + and - and not have to switch the trigger in the menu?
EDIT: added pullup on output and swapped inputs.
How is the INJ wire hooked into the injector wiring? Is there a shunt, or does it tie right into the ECU side?
