Old 10-12-2010, 02:00 PM   #24 (permalink)
jackbauer
jackbauer's Avatar
Your too big concerns there are driveshaft clearance between motor frame and motor to frame rail clearance on the far side of the engine bay. Are you keeping the clutch?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
