Gasman what state do you live in.
When you get some good links on building them post it up and hopefully we can add a how-to to the wiki.
Since I'm not sure how one actually works I'm going to suggest it any way when you have the extra gas that you are not using it could probably be piped back the the air intake on the gasifier. Also look in to the rocket stove for the burn chamber.
Almost forgot if you disable the EGR and use its location for pumping the gas in it should equally mix with incoming air. I assume the truck has a separate unit for the EGR.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Reason: Forgot about EGR
