Old 10-13-2010, 03:07 PM   #16 (permalink)
tjts1
Originally Posted by basjoos View Post
It has that real world advantage when they give the automatic a taller gear than the manual. I wonder what the results would be if the automatic and the manual had identical gear ratios.
Nobody would want to buy a car like that. Try driving a double clutch gear box some time. A human being will never shift the way this thing does. The shifts happen much faster and much more often. It'll accelerate in third and immediately jump up to 5th or 6th as you start lifting off the gas. decelerate down to a stop and it'll keep the trans in 6th gear the whole way to minimize revs with the injectors turned off. Basically any time you're not accelerating or climbing a hill, you are in 5th or 6th gear no matter how slow you're going. Since the shifts happen so much slower it would be a waste of time for a human to try to mimic its behavior. Instead they would be frustrated by the overly tall gears. I encourage anyone to drive one of these. Its very different from any automatic I've seen. My experience was in a VW with a very similar double clutch box.
