Old 10-13-2010, 09:22 PM   #19 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Otto View Post
Zip ties seem an excellent idea. If you need local reinforcement of the Coroplast, simply insert a short length of wood dowel of the right thickness into the Coro flutes and tie the Zip around that. (Distributes the load while reinforcing the plastic.)
Good idea !
A thin metal rod (or even thick wire) would easily fit into the thinnest coroplast.
