Old 10-14-2010, 05:25 AM   #12 (permalink)
crexcrex
pull side mirror, grind or use forty grit sand paper, fill with short strand fiberglass or bondo sand to doors contour, prime n paint looks stock................your method is tedious and the blank you installed is not flush and has gaps that will allow water and air to enter, plus drag prone...............
you wanted a opinion.................crexcrex
