Old 10-14-2010, 08:29 AM   #426 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by adamj12b View Post
The problem is you cant scale the drill file differently from the board files.
Hey Adam,
I looked at the BatchPCB Faqs page, they are requesting a 2:4 trailing format output for the drill file. It sounds like Paul did a 2:2 format output.
The drill file needs to be re-generated in DesignSpark PCB database with the proper trailing format output (2:4). It is not something that you can hand edit.
The gerber naming can be hand edited like you said.
I got you email, will look it over
-Mark
