Originally Posted by Daox
It looks like all of your injectors splice together at junction l12.
Don't junctions happen inside wire bundles? I could not figure out how they worked in my xA.
There is another option - the single black wire/white stripe coming from the ignition switch goes through pin 8 of connector IG1. This is located in the same place as the splice - it's a 10 pin connector with two large central pins - one of those is #8. The male/female end connectors can be seen on page 8 of the connector diagram. You should be able to get to it by popping out the glove box.
