Old 10-14-2010, 04:46 PM   #24 (permalink)
Niner
Niner_xA - '05 Scion xA
90 day: 35.82 mpg (US)
Horse Hauler - '95 Ford F-250 XLT
90 day: 13.47 mpg (US)
Butterkup - '02 Mazda Miata
No, the only thing that is connected at the #8 pin is the keyswitch to the injectors. Nothing else will be killed.
Also, if you decide on the relay, here's how to wire it. You can run a very light gauge of wire from the relay to your switch (and then ground). I also used a male and female disconnect to hook to the relay I used, so that I can pull it out and plug them back together if I take it back to the Toyota dealer.
