Old 10-15-2010, 11:07 AM   #157 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Varn, were you wearing PPE when you broke out in hives? While working with epoxy, I like to wear nitrile gloves, which do generally end up sticky. When I'm working with polyester resin (e.g. Bondo), or with epoxy in poor ventilation, I also add a respirator.
Jim, thanks for the update. I look forward to the next one. Hopefully, you can grid charge your battery, since it was sitting for four months.
How much does it weigh? Are you happy with your mounting points and the rigidity of the assembly?
