Old 10-16-2010, 10:46 PM   #172 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
One inch board can work well. If you really in your heart think that you need more than that you can always use a bit of epoxy and micro and glue two or more boards) boards together. Blue board is about the same as pink board.
I have used two part foam as a glue to put two boards together. It is very sticky.
You can always try to make a metal frame and cover it with polyester fabric,$1 a yard on ebay. Heat will shrink it if needed.
Noah Webster, 1787
