Old 10-17-2010, 09:53 AM   #121 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by dcb View Post
because that is logically the most efficient mode, even in parallel operation, and a good driver can take advantage of higher peak efficiency parallel provides. Aren't the efficient turboshaft engines like the size of a room?
Not all, some very small units are in the 40's, they are just much less common than the big boys due to the applications they use them for.
The other way around this of coarse would be a diesel genset but they are all over the map eff. wise as well.
Also, no offense but 50lbs verses 200lbs is a consideration. Also smaller is usually cheaper which is another measure of efficiency.
And a motor that is SMALLER than required could be operated continously at its most efficient peak area regardless of the speeds I drive, If I had a genset that operated peak eff at full speed, it would be recharging my batteries all the time because I rarely travel full blast and have lots of stops. Whereas a motor sized just big enough to toot me along at 25mph would always be operating at its peak efficiency and would improve my range significantly enough that I would never have to worry about it. (I don't drive 200miles one way)
