Old 04-16-2008, 11:46 AM   #21 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by Who View Post
Most truly don't. That said, AWD handles better than FWD or RWD, even on perfectly dry roads. With some vehicles there is none or little rated difference in mileage although it's obvious there has to be some type of penalty given that you're tacking on several hundred pounds of additional metal and fluids.
Just having a 4th tire on a vehicle is wasteful. With a single rear wheel and drive going to that wheel, a differential isn't needed.
I Disagree
There was a time that I agreed, but then I autoXed a WRX. Pushes through the corners, have to approach at a much lower speed, just helps in gaining the speed back. An Excellent driver on the wet will be able to take advantage of this, but most will not.
I've beaten both WRX's and EVO'S (with good (but not GREAT) driver in the) Wet in an 89 Supra N/A auto (1/2 the power to weight, a decade older, and RWD)
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
