It is more like pink board Jim, rigid and somewhat brittle. I have not had it set up foamy like the spray foam. I have never used gorilla glue nor tested the stuff in walls. If you are have an alternative way of creating space filling then stick with it. I have used it successfully.
Originally Posted by 3-Wheeler
Varn
Is that two-part foam anything like Gorilla Glue as far as density when it sets up? Or is it more like the stuff that's shot into walls for insulation?
Thanks, Jim.
– Noah Webster, 1787
