Old 10-18-2010, 08:16 AM   #1 (permalink)
miket
One or two piece wheel skirt.
I wonder if i should make the wheel skirts for my truck out of fender trim plus a curved sheet or as single bent/molded/carved piece.
I want the wheel skirts to go down to the bottom of the rim. I want them to look nice.
The front skirt will be articulating so it has to be quite rigid yet also line up without gaps.
What angle or radius should the edges be to be aerodynamic? Should it be gentler than standard trim?
The rear tires have trim, its missing off of the front, however i would need deeper than stock trim to give 1" of clearance to the front tire for highways turning. The rear trim doesnt stick out far enough for the bottom 6" where the vehicle curves under but is otherwise good. Its grey with a chrome stripe.
