I do not know if it would work with size constraints but on instructables a guy took news papers soaked them in a 5gal bucket for 1-2days. Then he removed them and pounded the sheets of paper with a rubber mallet on the ground to break the fibers and make it easier for them to stick. After doing that to both sides he used a dowel rod to roll the paper in to logs let it dry and then started fires with it. You could do the same and when dry cut the paper logs to size.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
